I'm ready to try my throw line. (I've successfully used a pneumatic launcher for years.) I picked up a "Kutir" kit that is very similar to Thomas' Compact Weaver Throw Bag. Do I take the line out of the bag to deploy, or will it feed OK out of the compact bag?
72,
Don, K9DRP
Arborist Throw Lines
Re: Arborist Throw Lines
Don,K9DRP wrote: ↑Sun Jul 03, 2022 3:42 pm I'm ready to try my throw line. (I've successfully used a pneumatic launcher for years.) I picked up a "Kutir" kit that is very similar to Thomas' Compact Weaver Throw Bag. Do I take the line out of the bag to deploy, or will it feed OK out of the compact bag?
72,
Don, K9DRP
Experiment with it before you do a field deployment, but I have had great success letting the line feed from the bag. One side benefit is that you only have to repack the amount that runs out.
Check out Thomas - K4SWL's posts on QRPer.com. They have great information on selection and use of throw lines.
https://qrper.com/2022/07/the-arborist- ... radio-kit/
https://qrper.com/2022/08/arborist-thro ... eld-radio/
