9:1 unun 20m
KG4ZSB
9:1 unun 20m
Post by KG4ZSB »
I want to use my 9:1 unun with my 20m QCX mini.
What length wire recommendations?
Re: 9:1 unun 20m
This is my favorite reference for random wire antennas:
https://www.hamuniverse.com/randomwirea ... LNKUVVQdL0
Here's another with basically the same info:
https://udel.edu/~mm/ham/randomWire/
Rule of thumb for "random wires"- At least a quarter-wave on the lowest band you want to work, not a half-wave on any band you want to work.
I'm using a 35' wire with a 17' counterpoise as my home antenna.
Remember you need a tuner for these antennas.
Re: 9:1 unun 20m
KG4ZSB wrote: Wed Sep 27, 2023 5:54 pm I want to use my 9:1 unun with my 20m QCX mini.
9:1 ununs are typically used with random wire antennas, which are intentionally non-resonant. So, you would need a tuner to match the antenna to your QCX. An advantage of the random wire is its ability to be matched with an antenna tuner, for use on multiple bands. Since your QCX is a single band radio, this holds no benefit.
You might be happier with a resonant end fed half-wave (EFHW). The feedpoint (one end of the radiating wire) of a resonant half-wave antenna has very high impedance, so a 49:1 unun is normally used to match the antenna to the 50-ohm feedline and radio. When the antenna is properly constructed, the feedline can be directly connected from antenna to the radio, and no tuner is needed. This simplicity is a big advantage for field operations.
A resonant 20m EFHW has wire length of about 33 ft, but should be cut longer, then trimmed to resonance based on your use conditions (unun, feedline, target frequency, antenna configuration, counterpoise, and soil conductivity). There is some latitude for slight differences in soil conditions and specific setup, so length is normally set once (by careful trimming), as you finish making your antenna. Trimming to resonance is normally performed with an antenna analyzer, a nano-VNA , or lowest power transmissions from your.radio through an in-line SWR meter (with proper identification of your station for all test transmissions).
Hope this helps...
KG4ZSB
Re: 9:1 unun 20m
Post by KG4ZSB »
Thanks for the response guys! I have a small 49:1 that I will use for the 20m endfed. I'll see how that goes.
