The NOAA raised an alert for a strong (Class4) geomagnetic storm which
will hit Earth between this evening and tomorrow, the storm is
currently classified as G4 but given that the multiple flares may sum
up, it may reach the G5 level
https://spaceweather.com/archive.php?vi ... &year=2024
it will affect GPS systems, electrical grid and then by the way, the
propagation; my recommendation is to unplug your radios and disconnect
the antennas, at least before 22:00 UTC today, to be more clear, check
here
https://www.swpc.noaa.gov/products/wsa- ... prediction
click the "start" and then the "stop" button in the animated graph,
then use the horizontal cursor to move the graph indicator, you will
notice the peaks at 22:00 this evening and then at 02:00 and 08:00
(UTC) tomorrow
Strong geomagnetic storm approaching
