Let's start with the image hereKL7MJ wrote: ↑Wed Dec 06, 2023 4:38 pm Andrew,
How would you go about constructing the jungle job? For 28MHz, you'd need about a 16 foot reflector. Do you make it out of aluminum pipe or PVC with wire inside (or outside)? To me, it sounds a lot more difficult than a Moxon with a 3D printed hub - maybe because I've already printed the hub!
https://qrper.net/viewtopic.php?p=465#p465
now, the two reflector arms and the boom may be both telescopic, plus the arms will be in two sections and not in a single one like in the image, this will allow to fold the arms forward when closing the antenna, that way, by telescoping "in" the reflector arms and the boom and folding the two arms forward, the resulting "package" will be pretty small, the dipole wire could then be wrapped around the "aluminium sticks"
