Favorite portable antenna
KG5CMS
Post by KG5CMS »
Good evening.
Do you have a favorite portable HF antenna?
The Chameleon CHA LEFS is probably mine. I have homebrewed end feds before but mine are not as sturdy or robust and Chameleon's.
I love reading about antennas so please chime in.
-73 & Merry Christmas,
-Don KG5CMS.
Re: Favorite portable antenna
Check my antenna setup over in the field reports section:
https://qrper.net/viewtopic.php?t=150
I'm a big fan of end-fed antennas - they're cheap, easy to deploy and versatile. I've made several EFHW antennas including a couple with traps that work great without a tuner. I'm currently using a 35.5 ft EFRW with a tuner as my "primary" antenna. The most amazing contact with it was with Kazakhstan on 30m using a QDX on FT8 from northern VA (and he called me)!
The only time I've had an issue with this type of antenna was in AZ, where I couldn't find a decent tree to hang a wire in. Then I used my trusty magloop as a backup, successfully activating two parks.
