Simple ATU
Simple ATU
Covers all bands from 80m up w/o any band switching, for QRP it can be built using polyvaricons, in effect the hard to find parts are the twin air variable capacitors
full informations here
https://www.pa0fri.com/ATU/FRImatch/FRImatcheng.htm
and here is a nice version
http://dl4cs.de/funktechnik/ant/fri-match/en.htm
this ATU is easy to turn into a remote one since there's no band switching it's just a matter of using stepper motors or R/C servos to turn the variable capacitors plus a couple of relays for the hi/lo Z switching and for the ATU bypass (see second link above)
Re: Simple ATU
also see
https://www.hamradiosecrets.com/homebre ... tuner.html
although the links at previous post carry all the needed infos
Re: Simple ATU
Andrew (grayhat) wrote: Mon Mar 31, 2025 3:33 pm ... there's no band switching ...
I was just reading through W6SAI's antenna book, and he has a Z-match that switches in additional capacitance that allows a tuner to cover 160 - 10m!
I have a ZM-2 (Z-match) as well as some small pi and T-match tuners, and I think the Z-match is the most flexible in terms of frequency coverage.
k8zfj
Re: Simple ATU
Post by k8zfj »
I agree about the z match. Have built several blt+ that worked just as well if not better than an em-2
k8zfj
Re: Simple ATU
Post by k8zfj »
Re: Simple ATU
The Fri-Match is derived fron the Z-match, full story here
